Just thought I'd pop in and say Hi.
I've been hovering as guest for quite a while and been looking for an Enfield related forum for hints tips and problem solving, this seems to be one of the best so here I am.
I bought a 2012 Royal Enfield Bullet EFI in November of that year, I had a screen and Givi panniers fitted and rode through the winter to the first dealer service, the next few thousand miles passed without problems apart from the headlight fell out once, and the sidestand cut out kept operating at unfortunate moments, normally when overtaking. So with a search of the forum, decided disconnecting the switch was the best option. I carried out my own second service this year, all went well.
Now with 6,000 miles on the clock, the OEM drive chain is stretching really quickly, the nylon swingarm bushes have worn out giving nearly 3" side to side movement of the rear wheel, right side mirror cracked through vibration (I guess)and the battery failed, spraying the left side engine cover with acid which is now nicely etched.
Sounds like a lot of issues, But I love the little Bullet, starts second kick or a few turns of the starter (with a good battery) and takes me with out fuss on my 200 mile round trips at 65-70mph without having to worry about stopping for fuel etc.
So now winter is hitting us in the UK with a vengeance, its time to put right a few of these issues.
I have now fitted a gel battery which should solve the acid problem,
In the next week or so I will be installing an 18tooth front sprocket and 102 Reynolds chain (which should help with the high cruising speed vibration), isolastic swingarm bushes and some mirror vibration dampers, I have already fitted some rectangle mirrors to replace the awful OEM round ones.
I am also fitting a pair of legshields and a 1950's Avon looking dolphin nose fairing, which should help with the savages of winter, I intend to replace the Givi 21panniers at some point as they are to small for me and the plastic locking arrangement is terrible, one pannier fell of , melting the front corner to the exhaust which I have since fixed with an alloy plate covering the hole in the pannier and use a nylon strap on the grab bar to give the panniers extra security......
so that's it for the moment, Ride safe
