Author Topic: Largest tires available?  (Read 12992 times)
Travman
on: October 04, 2014, 05:13:50 pm
Hi guys. My name is Travis and I just picked up a 2007 Royal Enfield (pictures coming soon). My bike has rather large tires on it compared to other Royal Enfields that I have seen.  I like the look, but I'll need new tires soon. What is the largest size I can put on the front and back?  Thanks in advance for any assistance you can provide.
Reply #1 on: October 04, 2014, 05:22:48 pm
Anything larger than a 3.5" wide front and 4.0" wide rear is overkill and just a fad.  Lots of people seem to be getting on the over-sized tire band wagon, but the truth is any tire that is too large for the wheel itself and the bike's geometry will actually hinder the cornering and ride quality of the bike.
Travman
Reply #2 on: October 04, 2014, 09:12:48 pm
Are the Dunlop K81's listed in NField gear too large?  They are listed as 4.10 x 19. Does the 4.10 denote the width?
http://nfieldgear.com/enfield-store/aftermarket-parts-accessories/tires/dunlop-k81-tire.html#customer-reviews
Reply #3 on: October 04, 2014, 11:02:06 pm
Yes, 4.10 denotes the tire width is 4.10" wide.  It is pretty much as wide as you can go on the rear.  And I really doubt that big of tire will fit the front without rubbing the fork tubes.  Not sure what kind of tire you are specifically after, but the Shinko 705 tire is bad ass.  Excellent handling on dry and wet pavement and does very well in dirt too.  I've had them over 100mph on a 650 BMW and they were very stable, have also gone down dirt trails/roads at 45mph comfortably.  It's only downfall is it gets slippery in actual mud.  Hands down the best dual sport tire I have ever run on a bike, not to mention the price is fantastic.
http://www.bikebandit.com/tires-tubes/motorcycle-tires/shinko-705-motorcycle-tire
Travman
Reply #4 on: October 05, 2014, 01:17:36 am
Here is my first Royal Enfield. I'm not sure what size tires are on the bike right now. Part of the deal of buying this bike is that the shop is going to put new tires on it. I figured they would simply replace the tires with what was on there, but evidently they don't have a source for those tires. So they called me earlier and asked if I had a preference.
Reply #5 on: October 05, 2014, 10:47:00 am
K81 is an unusual vintage sport tire with a "trigonic" shape. Probably not the best choice for a military.
K70 would be the typical Dunlop brand choice for that bike.
Bullet Whisperer
Reply #6 on: October 07, 2014, 01:41:20 pm
A 3.60 section tyre is equal to the old 3.25 [inch] or 90/90size.
A 4.10 section tyre is equal to the old 3.50 [inch] or 100/90size.
A 4.00 [inch] section tyre is wider than a 4.10 and around the same as a 4.25/85 or 110/90 and is probably the widest likely to fit a Bullet [rear].
 B.W.
Reply #7 on: October 07, 2014, 07:05:36 pm
            Can you reach the pedals yet?   :) :)   ;)
             Good luck with it.
Superchuck
Reply #8 on: October 08, 2014, 12:24:30 am
"a 4.10 and around the same as a 4.25/85 or 110/90 and is probably the widest likely to fit a Bullet [rear]."
BW, would that (largest) tire size also fit the front? My forks and front fender are stock Electra 2009.
Thanks!
Bullet Whisperer
Reply #9 on: October 08, 2014, 09:41:59 am
Thanks!
Hi Superchuck,
 If all the standard fittings are on the front, I think a 3.50, 4.10 or 100 section tyre [all much the same as each other] might even be a bit of a squeeze over the standard 3.25 [also 3.60, or 90 section] tyre size.
 Without a front mudguard, we got these fat 18" diameter tyres onto this bobber - from memory, they were 4.25's.
 B.W.
 Edit - just checked here and they must have been the 130/80/18 size ...
http://www.dunlopmotorcycle.eu/dunlop_uk/mc/tyres/on_off_road/K180.jsp
« Last Edit: October 08, 2014, 09:47:14 am by Bullet Whisperer »
Superchuck
Reply #10 on: October 08, 2014, 04:15:19 pm
Cool thanks for the info. That's a good lookin bike... I'm nearing 10k and expecting to have to replace my stock tires soon. Front tread is getting pretty low. Rear has some life left to it but I'd want to replace them both whenever I do. I know it's a trend but that's the style my Electra's becoming. Don't want to lose the front fender altogether so may have to look into other options.
boggy
  • Karma Ultra: 7
Reply #11 on: October 08, 2014, 07:38:52 pm
I have the Dunlop K70's on the front and rear.  Both are 3.5 and the front fender stays BARELY clears the tire.  The fender itself has enough room but the space between the fender stays and the tire is tight.  I seriously doubt the 4.0 would fit with the stock fender on.  There are two pics of them on my bike here:
http://www.enfieldmotorcycles.com/forum/index.php/topic,10916.msg177285.html#msg177285
« Last Edit: October 08, 2014, 07:41:51 pm by boggy »
2007 AVL
2006 DRZ400SM
AgentX
Reply #12 on: October 08, 2014, 10:04:14 pm
Can a true 4.0 even fit on the rear?  (The K81 4.10 are measured differently, from what I understand).  The Heidenau K34 comes in a 19"x4...always figured it was too fat for the swingarm.
Adrian II
Reply #13 on: October 08, 2014, 11:37:57 pm
Some 4.00" tires will partly fit, that is with the rear wheel at the farthest end of its adjustment, but will not allow the wheel to be adjusted fully forward. The Avon AM26 4.00"x18" being a good example, the actual width of the one I tried on my project bike was more like 4.375".  ??? (Replaced by a 100/90x18).  Check the tire manufacturers' web sites for the actual width, 4.00" = 101.6mm.
Some nice features on BW's Asbo custom, there's the basis of a great-looking flat tracker in there.
Regards,
Superchuck
Reply #14 on: October 09, 2014, 03:41:53 pm
Quick question- don't our avl Electra's have 19 inch wheels?
