REG5 -
I found some pics I posted when I removed my swing arm.
On the left side, you've got the axle "head" and the snail adjuster outside the swing arm plate, and the two spacers between the inside of the swing arm plate and the hub:
On the right side, you've got the castellated axle nut, the larger spindle nut and the snail adjuster outside the swing arm plate (not shown), and the spacer between the inside of the swing arm plate and the brake cover plate:
