Greetings,
Topped off my gas tank recently on my 06 Electra to find that it was leaking from under the front part of the cap. I pulled the cap off in hopes of being able to replace the gasket somehow. However, it appeares to be crimped together rather permanently.
I gave the gasket a coating of brake fluid (which I have been told does soften and preserve), I'll let you know if it works.
Other than replacing the cap (which I assume is readily available) has anyone else have any tricks or suggestions.
thank you,
GB
