Any updates on production?
Just curious.
How much difference would there be to have the stock head modded? I know the valve angles help get more in and out of the engine and that the higher ratio rockers are based on the valve angles and work together.
But in street terms, how much would I be leaving on the table? How much of what you've designed into this head could possibly transfer over?
We have done a few jobs on the stock head. They come out pretty well, given the limitations. We can do just a little, or a lot, on a custom basis.
The way it works out is that the closer it gets to the features of the billet heads, the closer it gets to the cost. In the end, it can't get all the way there, but it still costs a lot for a high end job. There is a lot of welding and hand work that adds up.
When the mods started costing over half of what the billet heads would cost, and still lacked lift, needing cams or custom rockers, it really started making sense to make the whole new head and all the design improvements.
But, we can still do the stock head work at a variety of lower price points, depending on desire and budget. Starting at a pretty low cost for a basic performance port and valve job.
The thing is, that these heads need lift. That is expensive to do whether you buy cams or custom rockers. But, ya gotta have it, or the flow just isn't there.
We can port it with the stock valves still in it, and get about 190 cfm intake flow, which is pretty good, especially for the money. But it needs over .400 " lift to do that, and needs cams that will lift that much or more. With stock cams and rockers it only flows a few percent more than stock. So you would absolutely have to buy cams to get anything worthwhile from it. With the billet head, you don't need to buy cams, so that offsets around $300 of the cost right there.
So, for people on a budget, we can do a lot for a little money. But if you really want a better chamber and the best ports and the max lift at the valves, it makes sense to go all the way to the billet. It goes beyond what can be done with the stock head in a lot of ways. I realize that it is a lot of money, but it is a whole new head, and not a modded stock head.
We are working with the new shop, and are hoping for production to begin sometime in September.
