It will be possible to order the head with standard rocker ratio and use it with the hitchcock cams if I remember correctly. Would this combination be of any advantage?
I don't know what the lobe lift of the Hitchcock cams are.
Our max lift at the valve is .600". I think the smallest rocker ratio we can get is 1.5:1. So probably .400" or lower lobe lift is allowed with lower ratio rockers.
I do know what the duration of the Hitchcock cams are. I don't see any advantage to using lower ratio rockers just to use those cams. I think the stock cams with 1.7 :1 ratio rockers would be better.
Rocker ratio almost always trumps lobe lift, unless you are already at max rocker ratio, because it isolates the majority of increased moving mass inertia on the valve side of the rocker. Cam lobe lift increases moving mass inertia on the entire valve train. With rocker ratio, all the mass of the tappets and pushrods and half of the rocker itself continue to operate at the relatively lower speeds of the stock lobe profile. Only the masses of the valve/spring/retainer, and half the rocker are subjected to higher speeds. This is a big advantage when controlling the valve train at higher rpms with the valve spring.
The only time to consider cams in this platform would be for more duration when reaching for a higher rev limit. This would require other changes, such as bigger throttle body or carb, and more flxibility to move the rev limiter up the rpm range. In a higher budget racing application, we could envision needing longer cam duration. I don't think it will be needed for the intended street application within the PC-V rev limiter potential.
