You have our attention. ...
Okay.
A little more info.
It will have the same attachment points as the factory bike has at the intake and exhaust locations, for the factory inlet and exhaust systems to bolt on to it. It will accept the factory sensors and all such other bolt on things that it needs to have. It will most likely use the factory rocker covers. General shape should be similar, and similar finning.
Everything else in between will be different. It is a complete new cylinder head.
One of the reasons for this is that we are trying to eliminate the long waiting periods for having each customer's head modified by hand. It was taking 3 months for each job, and this was something that we wanted to improve. With the new heads, it should be available at fairly short notice, depending on how much I can stock at any given time, or short production time, so little or no wait. I think that this ready availablity is something that people will appreciate.
Also, it gives us the freedom to make a new head with a completely clean sheet of paper, other than having to have the inlet and outlet connections at the factory locations. We have freedom to design new combustion chamber, new ports, new valve angles and sizes and locations, new rocker arrangements, etc.
We plan to pack this thing full of advanced features, and it will all be in the CNC program to cut it out of a big hunk of billet aluminum.
So, there we are.
Exact details will come later, but I have outlined the idea for you.
Weren't expecting that, were we!???
