Crazy coincidence. I finally mounted the tach-only 8k TNT on my bike yesterday...it was delayed in a shipping error that made it take like 2 months to arrive, and then the bike needed some other higher-priority work done first.
I don't have a nacelle, so it's mounted on a bracket to the top triple tree. It also comes with a handlebar clamp. VERY neat-looking installation, especially compared to what was there before.
I have been on the phone with Pierre quite a bit, too, for two things: One, the install calls for one non-switched power hookup in addition to the switch. My bike has a tiny 4AH battery, and I was worried about draining it, and I didn't need any advanced features, so I wanted to set it up without the constant power source. Since rev count is set electronically, not via dip switches, I was worried I'd drop the settings when power switched off. With my unit, turns out this isn't the case.
I also had needle jumping with mine when I tested it out. I'm running a Boyer Micro-Digital (wasted spark) and Pierre thought I could use the filter accessory. However, I think the jumping turns out to have been a bad test lead...it runs pretty nicely now. We'll see if the filter changes anything.
I probably should have looked at an electronic speedo option but just didn't want an LCD screen on my Fred Flintstone bike...
Here's the old VDO setup (wrong tach for the job, my mistake...for a 4-cyl car) which needed a lot of wiring to run the dual light bulbs and was rigged into a pod setup:
Here's the Koso; MUCH cleaner install and built to be weather-sealed:
(I should have some better pics in a little while; will also video the action.)
