I think it's best to go 'open forum' on this one, rather than P.M.'s, so here goes ...
I have been asked about my top end modifications to boost the C.R. to 9.2:1, using the standard parts.
The piston crown needs to be machined inwards across the top from the outside edge by 10mm radially and to a depth of 2mm. This should leave a raised portion of the original top face of 64mm diameter and 2mm deep.
Originally, the piston crown should have come up flush to the top of the barrel at tdc, the 1mm thick head gasket giving the 1mm squish clearance required. If the 2mm deep cut is made on the piston crown, it follows that 2mm needs to come off the bottom of the barrel to restore the original 1mm clearance with a head gasket. 2mm will also have to come off the bottom of the liner, or it will touch down on the flywheels.
If for some reason, the piston crown came up higher [or lower] than the top of the liner before hand, this is the time to put things right and get the required 1mm clearance with a head gasket in place.
I have personally 'done' two machines in this way and funnily enough, the owner of the second one called in today to tell me how happy he was with it.
To anyone 'having a go', please follow the above advice and ask questions here and I will try to help, but I can't be held responsible for mistakes made by others trying to emulate what I have done. If you do what I did, to the letter, all should be well, if not, it might go horribly wrong, so please take time and care with whatever you do to your machines.
Thanks,
B.W.
