Just measure from the center point of the swing arm pivot bolt to the center of the rear axle bolt on both sides to check alignment. If those measurements are the same,... then there's trouble somewhere else. Maybe the weight of the pipe. Maybe the crown of the road, or maybe a bent frame. I'd break out a tape measure and eliminate at least one possibility within a few minutes.
