i don't have two forward drain plugs. i have two total.
i still haven't taken of the timing cover off to do all that blowing thru the holes.
i got a little intimidated with all the warnings of the shims and gasket thicknesses. my gasket is very very thin and looks like ultra black. i was going to do more reading on this and hope my gasket gets here so i can see how thick it is. ordered it from CMW should be here any minute now. i don't think they offer different colors or thicknesses.
and to pull the pump out and clean it up I'm pretty sure i need the cover off. i assume by the pump you mean its components, both discs and the worm spindle. then i can replace the nut , blow it out , make sure all is clear and put back together.
since i don't have a drain in the case where will i make sure that passage blows to, in the filter housing?
The timing cover does not have to come off to access the oil pumps. Only to get to the spindle and worm nut will you have to take off the timing cover. Each oil pump has its own little oval shaped cover.
If you are worried about taking off the timing cover, then don't do it.
You don't have to worry at all about the filter housing or any other parts that have to do with the feed pump. You have oil at the crank, and that means your feed pump and your filter flow and all that feed stuff is okay.
Your issue seems to be with the return side. There's not much that can be wrong there, as long as the pump is working. Blow out the return side exit passages, and blow out all the external oil lines and clean out the banjo housings and banjo bolts real good, and make sure that the little oil hole above the drain plug is not getting covered when you screw in the drain plug. Then go ahead and start it up and give it a little bit of time like a couple of minutes, to see if oil is coming out the external oil line fitting. It will take a little bit of time, and it won't gush out, but you will get some flow.
