Hi Scottie,
Thanks, I was planning on using Hitcocks rods, and after talking to BW about pistons will use the Wiseco T110 pistons.
The look is evolving based on what comes up on eBay, the shrouds initially will be hiding some seen better days forks, eventually may go disc brake like I have on the Bighead. Ignition will be PowerArc, as I have the programming kit, and it works really well on my other Bullets. Primary and clutch will be Bob Newbie, as I don't have a primary or clutch yet. Before I sent the shrouds off for powder coating, I spot welded some 16swg Zintec plates on the inside to strengthen them, so hopefully my light won't fall off.
The pictures show my trailblazer crank cases, but will build the bike with my later Constellation motor and crank, as the lubrication system and crank are much improved.
I am looking forward to see what difference the heads will make, as a friend has an Interceptor mark 1, and it will provide an interesting comparison.
Things may change, but this is my plan at the moment.
Kevin
