........Attached is a pic of my wheel, installed. You can see the axle end, snail adjuster, swing arm plate, black spacer, and small "silver" spacer, which has a flange......
Just for reference, following is the detailed part list.
Damn! To be honest, I'm glad that the tyre/big metal spacer combo held up and you had to remove the tyre within a short period of time. Otherwise you would've kept riding, and who knows what might've happened!
