Thanks for the advise ... I've checked connections , battery , and so fourth . I don't have a air box , but I checked the vent tubes and there's no major oil in them, just residue . I have a CDI system factory install. I know the carb is rebuilt correctly, I've rebuilt endless 2-stroke carbs..I have checked the flow rate for the float yet..I even check the fuel cap to make sure it's breathing out, checked for leaks all the way around the fuel system , rubber boot , lines..
The one thing I thought was strange is the air mixture screw is only back out 3/4 of a turn ,but this is what it was set at so I put it back the same .. I know my scooter and dirt bikes are all about 2 to 3 full turns
More details on the issue.. It starts no problem, idles great.. Even on center stand cracking the throttle it runs and sounds good.. So when I take it out in the street, 1st gear thru 3rd changing gears are good, then when I slow down it starts it's cutting / back firing..and has died when I come to a stop. Starts right back up and off I go and it starts cutting out as I give it gas, jerking as if it wants to die..
Even at a steady speed of 25 mph it will start cutting out, like turning the key on and off..
It starts all of this once it's warm, when cold it doesn't seem to do it as much but that's only a few minutes, I live in AZ.. So the day it started I was the 1st time I took it to 75 mph and longest distance of 50 miles .. Mostly was cruising at 65 and not holding it steady at that speed..that's when it started cutting out for a split second, enough to feel it.
This is my 1st Enfield and I love it.. It's modified as minus the engine itself.. The pipe, carb, air filter were done at a Enfield dealer shop . It was re jetted for pipe and carb..this is the way I bought the bike and have all the documentation ..I ve put 400 miles on with no issues at all, And now this..
Thanks again for your help and advise..
