geoff,
Do you have a breakdown of which lights you put where? Also, you said 6led Ba9, I can only seem to find either wide angle or 4 led "superbright" bulbs? I would verymuch like to convert to LED's! After one of my co-workers got rear ended while stopped at an intersection on his BMW last week I am also considering changing the brake light to the panel of LED's that "flicker or strobe" when the brake is applied.
sqf, do a search on the forum for LED. You'll find extensive threads where I discuss the bulb arrays I made and which I used. I also bought a "light bar" for the rear to increase visibility, from
www.customdynamics.com. You'll need to switch to a digital flasher unit as well. You can get everything from
www.superbrightleds.comLet me know if you need more info.
