Great info guys! Well recovery are on their way to pick me up from work which means a free ride at least (have to find some positive in this scenario - No pun intended )
Then on the weekend I'll run various diagnostics, Just glad to get it home at least.
I was already on the fence about trading up for a Triumph street tripple and I'm starting to be swayed even more I'm sure that will change once I work out the issue here.
Yep, charged it up over night and getting 12.5~v I've even contacted the seller of the battery and they were very nice and offered to send out a replacement just in case - So I'll be able to test that out next week just to rule it out.
A fully charged battery reads between 12.8 to 13.0 volts.
It may seem small difference but after an overnight charging it only reads 12.5 volts, it is NOT fully charged and indicates something wrong with battery.
When the vendors say
'we send charged battery, just install it' means nothing more than 12.5 volts ! They did not test the voltage of the unit sent to you. That approach may work out fine for a car because a car's alternator creates 14 volts
at idle which is enough to charge battery fully to 12.8 volts as you run car for next several days.
However a Royal Enfield does NOT produce enough current at idle or even at low speeds to charge the battery that is already low. RE creates about 12.7 volts at idle with lights on - NOT enough to reverse the discharge rate. So the battery keeps on draining further, at a slower rate but discharging nonetheless, or barely maintains its level.
It takes about 14 volts to reverse the process of discharging of the battery. By charging I mean bringing UP the voltage from 12.5 to 12.8 volts.
RE can charge (stop discharge) only when it is running at HIGHER rpms.
PS - While I was typing SteveThackery was too ! I read it afterwards and agree with what he wrote. The battery may have been fried by high voltage. But your post of 24 volts does not indicate WHERE was that recorded - at battery or alternator ?
PPS - The rectifier/regulator should be tested as JVS has posted a link for that. Very likely it is a wiring connection problem.
You may also check this video on battery voltage of RE and alternator output -
http://www.youtube.com/watch?v=p6GnwkCXPi4
