You need to get tha Barnett part number I specifed.
It is not listed as Royal Enfield.
It is listed as Greaves-Villiers because they also used the Albion gearbox.
AVL plates are for the 5-speed , but they should also work. They are probably thinner because of the 5 plate stack in the 5 speed.
