This is also done on the exhaust side for the same reasons. Two stroke engines can have mechanically driven guillotine or rotary door valves in the exhaust port. Some sport bikes have electrically controlled valves in the exhaust pipe itself.
If your aim is pure power these devices are probably worthwhile. In normal use I don't believe the electro/mechanical complexity and cost are worth the trouble. These type of intake and exhaust devices can smooth out power delivery, but so can learning proper throttle technique. And while these devices also offer potential power gains, if you are not racing at Daytona it's kind of a moot point.
