Hi Thumper,
I have a Velocity Stack air filter.. When I engage the choke level, there is a rectangular slide (called the air valve, apparently) which is situated inside the throttle slide, which lift upward and become none visible.
do you think it means that the choke is actually off? cause I had the feeling that lifting this bar inside the the throttle slide was increasing the volume of the air chamber and therefore having an effect on the mix... effect which I obviously do not understand, I must make this clear.
How am I looking for something to far there?
thanks for the link.. and for your help
