That bolt also sheared off on my G5.
It is the lower rear engine mount and if you tighten it down to the torque recommended in the Service Manual and you used a normal bolt to replace it, it will shear off again. The nut/bolt should be torqued to 50 N/M (37 lb/ft).
The size is a M10 X 260mm length and I couldn't find one in a high stress material.
I didn't want to wait for a week or so for a replacement bolt from CMW plus they probably wouldn't sell me one anyway because I'm not a dealer, I used another method to solve my problem.
At my local Ace hardware store, they sell threaded stock and nuts. They have a low cost low strength threaded stock but it will not take the loads that are needed.
They also had a rather high cost heat treated threaded 3/8-24 UNF threaded stock which I bought. I also bought two grade 5 nuts in that thread size and two steel flat washers. I had to buy a new HSS hacksaw blade to cut the threaded stock down to the needed length. (My old used hacksaw blade would barely scratch it. It's that tough,)
Anyway, with that torque applied, my fix has lasted over 2 years. Oh. At the high loading produced by that torque, you won't need any blue thread locking stuff. The 7900 pound load from 37 lb/ft of torque will keep it from unscrewing.
