Duvall
August 02, 2015, 01:03:29 pm
Author Topic: 7" Conversion Headlights  (Read 307 times)
NField Gearman
  • Administrator
« on: August 19, 2014, 10:32:36 am »
Just a quick heads up, we only have a small handful of both our 7" pre-assembled conversion headlight and our 7" conversion trim rings.
If you have been on the fence about ordering one of these, I suggest you do it now or you'll be installing yours in November, when our next shipment arrives.
http://nfieldgear.com/enfield-store/pre-assembled-7-headlight-kit.html
http://nfieldgear.com/enfield-store/7-headlight-conversion-kit.html
This is by far the most popular upgrade for US Royal Enfield Bullets and although we bring these in by the container, most are sold before they even get out of the truck. Grab yours today!
DanKearney
Re: 7" Conversion Headlights
« Reply #1 on: August 19, 2014, 02:33:21 pm »
Does the headlight retain any aiming ability after this conversion is made?  My stock one already stares off into space at maximum adjustment.  Is aiming any easier with this conversion installed?
Cheers,
Dan K.
NField Gearman
  • Administrator
« Reply #2 on: August 19, 2014, 04:00:04 pm »
This is indeed adjustable.  I can't say aiming is easier, but it is certainly built into the unit.
DanKearney
« Reply #3 on: August 19, 2014, 04:13:56 pm »
Thanks for that info.  Now time to ponder. . .
Cheers,
Dan K.
« Reply #4 on: August 19, 2014, 07:13:57 pm »
I bought that kit a couple years ago, it wasn't adjustable then.  Has it changed?
NField Gearman
  • Administrator
« Reply #5 on: August 20, 2014, 08:58:55 am »
Whoops! The 7" is NOT adjustable.  It's a fixed beam.  My bad.
The_Rigger
« Reply #6 on: August 22, 2014, 01:59:23 am »
I was about to say... No; the 7" kit is definitely NOT adjustable. However, my stock 5-incher also stared off into space, even cranked down as low as I could get it without damaging anything. Replaced it with the 7" kit and visor, and wonder of wonders; the light goes right down the road where it should. Give it a try...
-Dave
2012 C5 Special
