an exhausting day!
decided to fit the efi muffler today. i have fitted 3 previously to the uce bikes so no big deal....wrong!
after undoing the standard run of bolts that hold the original exhaust system on - no matter what i tried i could not get it to budge one bit. like i said earlier i have put them on 4 other bikes. some were a bit hard but with a bit of wd40 and up/dowm sideway movement they all let go pretty well.
there is no way i could get it off so i thought angle grinder and cut the exhaust but at the last moment decided to work back along the exhaust. after that use a screwdriver and hammer to free but still -no go and stuck solid.
back on the forum for advise and 'Ace' mentioned peel the exhaust back. after a couple of hammer hits and nothing thats exactly what i did. a few up and downs etc etc and it broke loose. damaged but loose.
finally happy with the end results i then used the sander to smooth off the damage from the grinding incident
two hours later i placed the exhaust into the final resting postion. this time hitchcocks efi muffler was a very tight fit on the factory style header pipe. plus they had mad a couple of changes.
first off the perforated disc was set a little further inside the muffler than usual and in a concave pattern. plus the exhaust bracket was longer and would not line up with the rear footpeg contact.
looking at this photo you will see it now hooks up to the original front mount point
when you look at my old maroon c5 - the hitchcocks muffler is attached to the rear footpeg
so after the fitting i took it on a 100 klm run. a bit more noisier but i think i may drill out 3 or 4 of the perforated holes in the exhaust. it worked well for me last time so will do it again. maybe tomorrow -maybe not! ...lol
