Author Topic: Does this sound right????  (Read 4023 times)
armando_chavez
on: August 07, 2014, 10:31:40 pm
this is what my bike sounds like after S cams that clicking is weird i checked for clicks before when i installed the s cams and i heard nothing but now that its running.....???
listen to the video heres the link...
https://www.facebook.com/photo.php?v=905422279484216&l=2187869723401126493
Reply #1 on: August 07, 2014, 10:51:29 pm
Sounds like valve clatter to me. A little too loose? Put a screwdriver on the engine with your ear to the handle to see if you can notice where it's loudest. That may help you figure exactly what's making the noise.  ERC
armando_chavez
Reply #2 on: August 07, 2014, 10:56:48 pm
what happens if its loose?
armando_chavez
Reply #3 on: August 07, 2014, 10:57:19 pm
should i have retarded the inlet cam by one tooth like others have done with S cams?
Reply #4 on: August 07, 2014, 10:58:47 pm
Another thing that can help determine exactly where the noise is coming from is a 2-3 foot long piece of garden hose.
Holding one end to the ear and moving the other end around the engine can rapidly narrow down the source of the noise. :)
If it's coming from the rocker arm covers, it's caused by loose valve adjustments so tighten them up just a bit.
Don't over do it.  With the piston at TDC they should spin freely when the engine is still cool, with just finger pressure.
Reply #5 on: August 07, 2014, 11:37:41 pm
  If it's loose tighten it up more. Do as Arizoni says. ERC
armando_chavez
Reply #6 on: August 08, 2014, 12:21:39 am
when i asked that i thought you meant the actual valves.  not the rods.  Ill be sure to span them a bit and see how it sounds.  i thought i had adjusted them proper guess not.
DanB
Reply #7 on: August 08, 2014, 04:42:27 am
Doesn't sound too different than mine. Was the engine warm or cold on the vid?  You did remove the exhaust valve lifter, right?
2006 AVL Electra
armando_chavez
Reply #8 on: August 09, 2014, 07:12:49 pm
that tick is normal? yes i removed the decompressor
Reply #9 on: August 09, 2014, 08:53:25 pm
I think it sounds pretty normal.
Maybe just a little louder than normal, but a lot depends on the microphone in the recording.
I think it doesn't sound worrisome.
Home of the Fireball 535 !
1 Thump
Reply #10 on: August 09, 2014, 08:58:34 pm
If you set the valves on a cold engine...and did it right...then leave it alone. It sounds alright to me.
DanB
Reply #11 on: August 09, 2014, 10:06:43 pm
On mine, when it's warm, I get the same tick. At cold, it's very quiet.
When you say decompressor, are you referring to the arm on the pushrod cover or so you mean the actual pushrod lifter sitting under the pushrod on the cam follower. It looks like a top hat. I saw it still there in one of your pics.
Item 17: http://www.hitchcocksmotorcycles.com/partsbooks/pages/4677/Crank_Case
2006 AVL Electra
Reply #12 on: August 09, 2014, 10:28:42 pm
Yep, sounds like valve noise to me.  How did you set your valve lash?
armando_chavez
Reply #13 on: August 10, 2014, 12:19:55 am
i took the top hat out. i put it in tdc and tightened it to the right point.
Reply #14 on: August 10, 2014, 04:18:27 am
Yes but what is your definition of the "right point"?
« Last Edit: August 10, 2014, 11:49:47 am by High On Octane »
