Some years ago I adopted this technique for Drain plug bolts & crankcase pan bolts: When I dump the oil & tilt the bike to make sure I've gotten it all out, I let it stand open overnight to let any residual drip out. I then thoroughly clean the threads with alcohol. After it dries, I replace my drain plug & washer using silicon form a gasket goo in the threads, which I allow time to cure before refilling. This makes an oil tight seal that lasts to the next oil change, even with the super slippery Mobil 1 I use. My 2010 G5 Deluxe is completely oil tight (& Bullet proof) except for the occasional drop from my rear routed crankcase breather tube. All the pliable dry silicon peels right off when I move the plug.
