2010 Royal Enfield
May 25, 2016, 09:56:27 pm
Author Topic: Stock to Performance TCI Wiring harness  (Read 373 times)
DanB
« on: August 07, 2014, 11:38:00 am »
This maybe a long shot...
I'm lazy.  I have the performance TCI in hand and I want to create an extending wiring harness from the existing TCI connectors and relocate the Performance box.
Anyone know the electrical connectors used on the stock TCI?  Make, p/n?  Just trying to avoid lots of individual wire splicing and make up a harness that let's me get back to green stock if needed...
2006 AVL Electra
boggy
  • Karma Ultra: 7
Re: Stock to Performance TCI Wiring harness
« Reply #1 on: August 07, 2014, 01:38:13 pm »
I don't have an answer for you, but I'm curious where you are going to put it.  Inside the right-hand, lockable side-panel?
2007 AVL
2006 DRZ400SM
DanB
« Reply #2 on: August 07, 2014, 10:38:51 pm »
The big plan is to delete both side panels and relocate the battery and TCI in the middle in a custom box (I have a shorai Li PO battery for kick start only; it's tiny).
Short term, I'll locate it on the left side with the battery. It came with a fixin bracket... Not sure how it mounts... I may use it.
2006 AVL Electra
boggy
  • Karma Ultra: 7
« Reply #3 on: August 12, 2014, 10:14:21 am »
Awesome Dan - I'd like to do the exact same thing and figure out a way to get a flat dual seat on there to replace the stepped, stock one.
Keep us posted on what you come up with.
2007 AVL
2006 DRZ400SM
