OK, I'm scalyback!
Singhg5, check the wires from the low fuel sensor, the diagram from RE show it being powered from the brake light feed !!! LOL!, (green wire) should be the red white (just below). I checked with my efi, and the wire colour from the fuel sensor IS actually red/white.
It did take hours to check against the bike and you are perfectly correct, I did take a guess about some of the EFI text, but took mine apart to get the wire colours correct!
Itwas a copy from my owners manual, but there is not much of the original left!
Thanks for the comments, Please let me know if there are more errors, like in the ECU.
scalyback
