Couple of things about this, Clamp. First, the last article you cite is distinguishing between old technology bikes and new ones, and says the window of opportunity to use the honing lines is in the first twenty miles when you use hard riding tactics. I'm not sure what technology was used in creating ours. Well, my bike came with 19 km on it, so the window was already pretty well closed. Then you have to remove the cylinder, rehone, and hard ride for twenty miles. Second, mine doesn't use any oil and the plug soot is just that, a light soot which Pete Snidal says may be due to not hot enough spark at the low RPMs, or a too rich idle circuit. However, because it is dry like this, it may be the former, not hot enough spark at low RPMs
Pete also says, and has said for years, not to hone an engine on rebuild, that it isn't necessary and may not be good. I think, now that I have 850 km on it, I will open it up a little and see how it goes. I can't go very fast, but I can get the revs up by staying in a lower gear.
We have had one forum member, Dewey, who advocated hard break in and seems to have had good luck with breaking his in like that, so he would be in your circle of agreement.
I still have more reading to do in what you have presented ...
Thanks,
LJ
