That's sure good to hear, Old Salt. Mine now has about half what your's does, but I'm reaching the conclusion that the more I leave it just as it left the factory, the better off I'll be. Tried a few things, like seeing how it ran without the air filter (opened her up) but then found some other problems like carb backfiring, smoke coming from the air filter box, etc. So today back to stock and I plan to leave it at that. May do some cosmetic things, as I really like the black engine and black striped rims of the Black Shadow, but the rest I will leave be.
By the way, did you get the machine ready for the salt runs? Also, do you ride the knuckle much or is that a show bike.
Thanks for the post,
LJ
The 41 knuckle is an everyday machine. But the Bullet is so much easier to start and ride that it usuall gets the nod over the other machines.
The land speed car is almost ready for Bonneville. Finally got the engine builder to finsh the dyno pulls. Engine and both the transmissions went in yesterday. Look closely at my avatar...you will see that the big tach on the dyno consol has it's needle at 8 grand. That's rough on a 500 inch gas engine with 16 to 1 compression.
My Bullet has a lot of modifications. Upswept megaphone muffler, baffle removed from header pipe, home built air cleaner, coil and horn in tool box, battery moved to central position, small mirrors and turn signals installed, bars moved, foot pegs moved 2-1/2" back, kickstarter moved in by chopping and re-plateing, all unnecessary electrical connections disconnected [neutral light and etc.], air scoop added to front brake, main jet drilled out, homemade sidestand, centerstand removed, plus a few other things.
I don't modify things to get better performance. Just want it to look more "retro". I love to ride the thumper and stay within the limits of what it was designed for. Can't see any reason to run ANY 500 cc single wide open in the heat of the day. This bike will last me a long time.
