The supplied bracket shouldn't be connected to the foot-peg. I've never seen a Bullet with a silencer bracket up at the footpeg. Unless you mean the stock muffler connecting point near the foot-peg, beneath the tool-box.
The EFI bracket is supposed to go where the stock muffler's small triangular bracket used to be. Yours might vary, but that's how I connected mine. That's why at the back of the silencer, there is a provision for adjustment to connect the bracket there properly. This is because each Bullet has little variations in its build.
Attach the provided bracket to the EFI silencer, with the bolt provided as seen in the picture, keep it loose for now. Then put the silencer on to the header pipe, match the bracket where the stock muffler's triangular bracket used to be, and re-use the stock M8 Hex bolt. Tighten the clamp first at the header pipe/silencer joint, and then the long M8 bolt, followed by tightening the bracket bolt at the silencer.
