yeah I could only get a black face of this speedometer off the supplier. I would have preferred white BUT I was lured in by the fact that this unit has wired in left and right indicators and high beam......so settled for the black regardless.
as to the white smiley face
not sure how i'd go moving it about as the ABS is hooked in there too
best thing though I like about this gps speedo say from scratch - once the ignition is turned on ( you can see the gps receiver on the handlebar mount) it does a quick count up on the odometer 1/2/3 and so on and locks on to the satellite within say 20 seconds and then the odo comes on and your ready to roll
after that anytime you turn it on its almost instant. speedo needle is rock steady at all speeds too.
