As for soldering all of the wiring connectors to the multi-strand wires, it is not recommended. A good crimped connection will give fewer problems over time.
The reason for this is, vehicle wiring, be it a automobile or a motorcycle is subjected to a lot of vibration. (Especially if it is on a big single cylinder machine like a Royal Enfield.)
Copper is a material that "work hardens". That is, if it is bent, it gets harder. The more often it is bent or subjected to stress, the harder it gets.
Hard metals are brittle and break easily.
What does this have to do with soldering vs crimping?
One of the reasons wiring in vibrating areas is multi-strand is to help it survive vibration.
As the wire changes its position while it vibrates different areas of the wire want to move at a different amount than other areas of the wire in the same location.
Picture a straight length of multi-strand wire. All of it is one length. Now, looking closely at the end of the wire, picture the same wire, bent into an arc.
The length of each strand of wire remains the same but the wires closest to the inside of the bent arc will begin to extend from the end of the wiring bundle because the distance around smaller arc length is less.
The wires towards the outside of the arc will try to sink below the end because the distance around the larger arc is greater.
If the wire bundle is crimped inside a connector where each strand is somewhat free to move, it will move and the stresses will remain low.
If the wire is soldered, all of the strands will be attached to one another by the solder so their lengths cant move. This will create a large amount of stress right where the solder starts.
Another thing that happens if the wire is soldered is, the solder will stop somewhere abruptly.
The thicker, solder coated area of the wire will resist bending much more-so than if there was no solder present.
This leads to the unsoldered area vibrating freely back and forth up to the point where the solder starts. At that point, it can no longer bend easily.
That creates a stress riser at this location which concentrates the bending stresses exactly at that point.
With the stiffer soldered area refusing to bend and the flexible area bending back and forth the meeting place work hardens much faster and coupled with the high stresses caused by the stress riser the wire will break.
The bottom line is, don't solder wiring joints on vibrating machines.
There's a good reason crimp on connectors are used.
