Son, I had no idea you were going to do the work yourself. I am impressed mightily with your checker application method, props to your finesse. I was a little skeptical with the brand logo being just outline instead of filled, but this works; I can see ahead with the finish coat~marvelous it will be in the sunlight and sinister at night. It will make people look even harder. Ditto on the tank top, it POPS! Please send your gun specifications, including orifice size, and paint/finish mix ratios and the relative humidity/temps at spray and cure points. Again, pardner, out of the damn park on the job!
