My 2010 C5
38 Guests, 7 Users (1 Hidden)
HiFi Guy, french180, mattsz, Ice, pearcey2, cafeman
February 06, 2016, 06:19:10 am
Author Topic: Cutting Out  (Read 2150 times)
smithstevee
Cutting Out
« on: August 05, 2007, 05:29:52 pm »
New owner of 2003 Bullet ES 500. After warming up, engine begins to cut out then dies. Restarts with choke. After thirty seconds, cut choke off and engine runs well for about two miles. Same restart with choke - then engine runs well for another two mile stretch. Any ideas?
RagMan
  • Bulleteer, Uralist &
Re: Cutting Out
« Reply #1 on: August 05, 2007, 06:08:02 pm »
Clean the carb, clean the airfilter. Make sure the gas in the tank is new, not been there forever.
aka Indiana Bulleteer.
Jefferson County, WA
Emmet
  • Tampa Bay Piper
Re: Cutting Out
« Reply #2 on: August 05, 2007, 06:17:03 pm »
While you're at it install a fuel filter.
dewjantim
Re: Cutting Out
« Reply #3 on: August 06, 2007, 03:10:28 pm »
Im not sure about your 2003 model, but my 2000 has a catch can under the air filter which will occasionally fill with oil from the crankcase breather system. If this can gets to full it will clog  your air filter with oil. You might check this along with the carb and fuel delivery system.....Dew.
