I put that plug (the iridium one) in my GT as the first step to trying to make mine run nicely. When I took it back to the dealer to see if he could make it nice (he couldn't) he freaked about the plug, said it was way too hot and installed a new standard plug back in.
Way too hot !? I believe he has his NGK heat range numbers reversed. That would be ONE heat range Colder. I believe the GT's come with an NGK equivalent of a 5. Which would be HOTTER then a 6. Lower number NGK = hotter.
And YOUR engine is configured a bit different then the 500's. I would not give up on the plug that came with the bike..... it seemed like a decent plug. Or at least stick with the same heat range. Because if you are having problems with cold starts, long warm up times, stalling out before it's fully warm, surging. THAT is an air/fuel issue that needs adjustment. It's not the plug , and certainly not ONE heat range difference. If you but in a NGK 5 on something that might be on the lean side... it may exasperate the situation. If you start putting in colder plugs , it may help a little to smooth things out some , but the issue is air and fuel.
