Will you be using a windshield? If not then you might not want the higher bars. The standard bar is already pretty upright and any extended time at 50mph+ is very tiring. I have the ace bars, they help with the sail effect, but would not be appropriate for 1000 miles.
I do plan on getting one eventually, yes. As for the factory bars, I actually do find myself a little haunched over with them, and a lot of reach. On my '01, my dealer had a source for bars that were a little bit more in each aspect - a bit higher, a bit wider, a bit more back. LOVED them. But alas, those bars are now unavailable!
Like I said, I'm hoping the "trials" bars are a decent compromise, but hey, they're just bars. I can swap'em out until I'm happy.
I have the 18-tooth on my 2002, I like it. It pushes the comfort zone in top gear up a bit to about 60 and allows for a very comfortable 50-55 with minimal vibes.
Had one on my '01. Came that way from the dealer. I had never ridden a Bullet with the original sprocket until this one. It took me a bit to realize why it seemed like it was revving so much at 55mph
You will love the 7" upgrade. I also have that and the improvement in light was dramatic.
had one of those on my '01 as well... but with the "tri-bar" lamp housing. It sucked ballz. Plus I kept blowing bulbs every few thousand miles.
This time around I'm just going with a standard fluted lamp housing and buying only "motorcycle" specific H4(?) bulbs, to see if that will help.
You might consider the high flow oil pump. 1000+ miles with minimal rest will be very hard on an Enfield and I would think improved oil flow would be well worth having.
had those on my '01 as well. Only thing I noticed was I sarted using a lot of oil, and blowing A LOT out the duckbill afterwards.
There seems to be a little debate over wether they're really all that nessesary?
I also won't be doing any SS1K's ever... My pace isually around 400 miles/day on the old highways.
I have the english style seat with the white piping. Not only does it look great, but it is wider and flatter. More comfortable than the standard seat by far. A sprung solo seat might work well too. The extra shock absorption from the springs could reduce fatigue from engine vibrations.
I was looking at that... couldn't tell if it was "flat" or if there was a step in it or not. Not crazy about the white piping though since I have a Military.
I had the deluxe solo on my '01. It was OK. I used a gel pad on it. I just thought it would be nice to have the freedom to move back and forth in the saddle a bit. Also, the front seat bracket broke on me in the Texas panhandle and I had to ride for a day with it rigged up and digging into my tender bits until I found someone with a welder. (suprisingly, not as easy as you would think in Texas ranch country).
The carb upgrade might be worth while since you will be going over some mountains. The 18-tooth counter sprocket is great, but it will have an impact on your ability to carry speed up a steep grade, so a little extra power would probably be worth while.
This is the biggest "iffy" one for me. Do I mess with what's not broken and go for looks & simplicity or just leave it be? I never had any "carburetion" issues with my '01 with the stok Micarb and shorty muffler & K&N. power was livable on the mountain passes... how fast do you want to go anyway?
I did however, go through 3-4 of the rubber adaptors, so eliminating that point of failure is appealing.
Thanks for the input!
