Thanks Boys.
I'll tell ya is was a bit of a head scratcher. My rear wheel always looked a bit "OFF" to me while looking at it from the back. It looked a bit left of center, or so I thought..... even with the alignment being good. So leveled the bike with some shims under the center stand, making damn sure the bike was level. And started measuring things in relation to various points on the frame.... first I thought it was a spacer cut wrong? .... Or maybe the shock mounts not being welded in the correct location?
Putting a level along side the back tire showed I was not plumb.... Even though the rest of the bike was level and the front wheel was plumb. So I was not left of center on the wheel, I had some positive camber going on ?... I was to the right on the bottom ?..... What the hell ?! So I pulled the back wheel and checked the swing arm and it was good, side rails nice and level ? So I laid the axle ONLY in the slots in the axle plates and put a level across it.... I was off. Not all that much, but a little low on the left and high on the right. I took the spindle, or collar out of the brake , slide it on the axle and laid it in there like it would be . WAY off !
It seems they didn't allow for the difference in height when the axle is slide through the brake spindle.... or they welded on the axle plates on at a different level. Long story short, I welded up the left side axle slot to add material to the bottom of the slot. Smoothed it and opened up the top of the slot. And just got the axle level WITH the rear brake assembly on.
This all should keep my wheel nice and straight, without any flexing in the arm.... by tying in the axle, to the cross brace and to the pivot tube, and looping it around. Especially when the wheel wants to pull up and to the right with the torque of the back wheel under load..... or as I'm on and off the throttle.
