Sunset ride
September 02, 2015, 05:18:06 pm
Author Topic: 1967 Royal Enfield with 567km. Starting Issue  (Read 1127 times)
Re: 1967 Royal Enfield with 567km. Starting Issue
« Reply #15 on: June 24, 2014, 06:30:57 am »
It's a Mikarb, which is a sort of clone of a Mikuni VM round slide 28mm.
This is a throttle slide carb. Not CV.
That's right, the AVL has the CV carb.  My bad.    :-X
RE_Chief
« Reply #16 on: June 26, 2014, 02:59:22 am »
Is this the motorcycle advertised on Craigslist at the moment for $33,000!!!!
https://columbus.craigslist.org/mcy/4533444554.html
Regards Charles
1955 Indian Tomahawk 500 twin
1958 Indian Chief 700 twin (SMPB 9002 the 2nd ever made)
1960 Indian Chief 700 twin
1964 Interceptor Mk1 750 twin
1967 Interceptor Mk1A 750 twin
1994 Bullet Deluxe 570 long stroke single
« Reply #17 on: June 26, 2014, 05:41:21 am »
Regards Charles
Maybe that last zero in the price was a misprint?
 ;D
JVS
  • I love chicken
« Reply #18 on: June 26, 2014, 06:01:17 am »
"Asking price is $33,000."
Oh Lord.
W
o
w.
What is happening  :-\
« Reply #19 on: June 26, 2014, 01:24:50 pm »
If that bike sells for even anything close to $20K, I'm taking the Blackhawk to Ohio to sell it.    ::)
« Reply #20 on: June 26, 2014, 01:28:49 pm »
Have you put any fresh gas in it? I'd drain the tank and carb and put in some fresh gas. See how much water, if any, comes out with the old stuff. Also take off the points cover and check for corrosion. How's the battery?
A bike sitting around for three months with no prep can lead to bad things.
« Reply #21 on: June 26, 2014, 01:37:06 pm »
Bein's that the picture he posted in the forum and the one on Craig's list are the same. it's a pretty good bet it's the same bike. And the way the ad is written, sounds like the price is not a typo.  I wouldn't want to say anything about misrepresentation.
rvcycleguy
« Reply #22 on: June 26, 2014, 06:06:25 pm »
I guess my 56 must be worth as much to retire comfortably on....
« Last Edit: August 03, 2014, 07:45:33 pm by rvcycleguy »
victortrry
« Reply #23 on: July 28, 2014, 01:00:09 am »
I have just back on this forum, I have a 1972  Enfield India 350 with a micarb on it.   The starting procedure I use is turn on petrol. pull choke on. Pull decompressor lever in kick it over a few times to suck some petrol in then turn on ignition.  Turn the motor over with decompressor until the amp meter just goes back into negative then raise kickstarter and give it a good kick it should start first go.
