Recently I had purchased a Koso Universal analog tachometer for installation on my G5. It turned out to be much longer project. The tach would pick up the signal but did not display correct RPM and was erratic, non-responsive to engine speed and throttle position. Many ways were tried but nothing worked.
When all options were exhausted, I contacted the company headquarters in Canada and sent them some pictures and description of what was happening. Their technical manager replied that it needs an ADDITIONAL device called RPM Signal Adapter to resolve the problem.
To my surprise I received that in mail in a few days, courtesy of the company
. Well, it was attached to tach and the thing is working as it should.
This tach has water temperature sensor also. A separate ring-type sensor for spark plug can be ordered, which I did. So now I can say for sure that the cylinder head temperature reached 253F on my last test run.
There are two videos - they contain different information.
The first one is about features, functions, operation and specs (power consumption) of this tach -
http://www.youtube.com/watch?v=huCFMM4nvlMSecond one is actual trials and tribulations of installation until I received the correct parts -
http://www.youtube.com/watch?v=3hMnm08CKOU
