Author Topic: Redditch Fury 500 carb settings  (Read 3112 times)
Bullet Whisperer
on: June 20, 2014, 01:46:00 pm
Redditch Fury 500 carb settings ...
 I thought this might be of interest for some - I have just finished setting up an Amal MK II 38mm carb on a genuine 'Big Head' Fury. It starts and runs perfectly and here are the settings:
 Slide = No3 cutaway
 Main jet = 380
 Needle jet = 107
 Needle = lowest groove [richest]
 Pilot jet = 45
 Starting jet = 60
 Air screw = 1.5 turns out.
 Full advance timing is 34 degrees BTDC [11mm]
Reply #1 on: June 21, 2014, 06:45:19 am
And here I am running a single 30mm MK I on my TWIN.     :-[
da punds
  • Fireball 25
  • One of Britain's most northerly Bullet fans
Reply #2 on: June 21, 2014, 12:02:37 pm
32mm Amal mk1 on the 570
34mm TM Mikuni on Bighead Fireball
15/16" Amal Pre Monoblock on Model CO
56 Trailblazer Gemini, Super Fireball BigHead, 59 Clipper 570, 39 Model CO + others(BMW, GasGas, Yamaha, Suzuki (rare GSXR-750R)), Mk1a Interceptor project.
da punds
  • Fireball 25
Reply #3 on: June 21, 2014, 12:07:53 pm
Sorry hit post before I had finished.
Thanks for the info, I have played with the MKII's in the past, mainly on Triumphs, and never really got great results with it, I see now I should have been more patient.
Kevin
Reply #4 on: June 21, 2014, 12:17:27 pm
Remember, your twin has 2 350cc cylinders which feed off that carb at different times during the engine rotations.  That 30mm carb is enough for that. The shared manifold ain't great for max performance, but it can service a modest street application.
Home of the Fireball 535 !
Mr.Mazza
  • Upside down thumping
Reply #5 on: June 21, 2014, 12:54:22 pm
As ace said, a bigger single carb is better than two smalls!
Plus more carbs = more things to tune ;)
Reply #6 on: June 21, 2014, 04:08:59 pm
It all depends on the size and application.
A carb that's too big can be as bad as one that's too small. Just in different ways.
When in doubt, size the carb the same as the inlet port entry.
Reply #7 on: June 21, 2014, 04:27:04 pm
Awe shucks, I was going to put a Demon 870 4 barrel on my bike.   ;D  Seriously tho, had I known more about my bike and Amal carbs before I bought the new 930, I would have definitely went with at least a 32mm.  I had a 30mm Monobloc on the bike so I replaced it with a 30mm concentric.  But I wish I had gone with a 34mm.  It is however in a great state of tune so I shouldn't complain too much I guess.  :)
Scottie J
jimbocan
  • THE FURY
Reply #8 on: July 24, 2014, 06:41:21 pm
I used 1.5 inch Amal GP on my Redditch Fury Racer 1970. See my post ask!!
jimbocan
  • THE FURY
Reply #9 on: July 24, 2014, 11:33:01 pm
THE FURY 1970 It might be better to go to my facebook and see and read about my Endfields.
