Thanks for the post, Ridge. Funny thing is that last night I ordered a K & N on Amazon, then just moments ago it was canceled by the vendor, no reason given, though they may have seen I was overseas and not wanted to deal with me. I have things shipped to my wife there, but pay for it from here. S--- happens.
I had read about seeing light through the filter, but assumed that maybe small vortices of whirling air might be internally set up that would fling the particles onto the oil in the filter, but your info on actual tests done on the oil itself seems pretty conclusive to me. It isn't silicates I would worry here about but the very fine dust that running over coral can raise. And I can't use the OEM filter (of which I have four) because it restricts my carb to the point that it definitely isn't getting enough air., and I found I can't compensate without maybe ordering in smaller jets.
So what to do?
Damn thing is that when I ordered the air filter i also ordered a kit to renew the filter and they came from two different places, and the kit has already been sent. I'll only be out maybe $15 with the shipping, but it isn't good.
Think I'll do a little more digging and see what I can come up with.
Any other air filtering suggestions you've read about? The air is generally clean here, so maybe just run without. We should be back in the old biking days when they never worried about filtering the air!
Anyway, many thanks,
LJ
