Does the Electra keep it's battery in the same location as the Classic?
I noted that, on my Classic, the (-) battery terminal is about 1MM from the frame, seperated only by the thin rubber boot. Check the battery mount and make sure it's tight. If the battery moved rearward, it might have worn through the boot and grounded.
Good Luck
