Soni
May 02, 2016, 10:01:07 pm
Author Topic: wrist pin(gudgeon pin) removal  (Read 537 times)
rtillery02
  • R.Tillery
  • 2012 C5 Bullet Classic / 2002 Iron Barrel
« on: September 15, 2014, 10:54:56 am »
Fixin to pull the head off my 2002 Bullet for valve work, is the piston pin generally so snug/tight that it takes the removal tool to extract it?
  While I am in there, I thought I'd upgrade the top end with the alloy jug & matching piston.
  I'm expecting proper compression & tolerable running temps, but I'd like to have all of my tools in order before I get in there, Thanks for any tips on what to expect.
Some Folks Grow Old & Wise, &
Some Folks Just Grow Old.
Re: wrist pin(gudgeon pin) removal
« Reply #1 on: September 15, 2014, 10:57:13 am »
The pin is easier to get in or out if you heat up the piston with a hair dryer or something like that, first. That expands the piston and the hole, and it's easier to work with the pin that way.
cafeman
« Reply #2 on: September 16, 2014, 12:34:28 pm »
If you check eBay there are at least 3 versions of wrist pin removal tools. One is the old style that resembles the factory piece, another by Motion Pro that has various sized heads, and another that has 14mm and 17mm heads which will press the pin out. Anywhere from $25 shipped and up
                     1996 Yamaha Seca II
                     1991 Husqvarna 350WXE
                     1991 KTM 250MX
                     2004 Husqvarna TC450
                     1995 Honda VFR750
Mr.Mazza
  • Upside down thumping
« Reply #3 on: September 16, 2014, 03:30:49 pm »
Heat removal and installation is the easiest way ;)
rtillery02
  • R.Tillery
« Reply #4 on: September 24, 2014, 09:45:41 am »
Well, while the head is in my local machine shop, I removed the barrel & was go'in to "attempt" the wrist pin removal, out with the clips...slid right out with a small deep socket & steady preasure, no tools needed.
  My top end looks "perfect", my 2 top rings were stacked but, everything mics' out well within tolerances, no scoring,smears...nothing, not expecting that with the 380+ deg. temps. it was running in the 7 mile trips twice a day.
  That's just too hot for my comfort in such a short distance, maybe the shop will find a loose valve seat or sumthin, a H/O oil pump is startin to look like a fair investment... what say ye?
Mr.Mazza
« Reply #5 on: September 24, 2014, 10:26:00 pm »
Hi flow oil pump can make a difference, more flow = more heat transfer.
rtillery02
  • R.Tillery
« Reply #6 on: September 25, 2014, 08:29:44 am »
Thanks Mr.Mazza, Is it common to replace ONLY the scavenger side disc with a H/O disc yet keeping the lower pump stock volume?
« Reply #7 on: September 25, 2014, 10:49:34 am »
Stock pumps already have scavenge exceed supply. It is necessary in a dry sump system.
"Hi output" pumps are not necessary unless you change the big end bearing to  a roller.
"Stacked" ring gaps are not really a problem as long as the rings move freely in the grooves. Rings rotate around the piston during running. Best to orient rings staggered away from the thust faces for the first startup after reassembly, though.
« Last Edit: September 25, 2014, 11:05:41 am by ace.cafe »
