Thanks for the link and info.
Obviously this is a semi common problem in dealer setup. Also it is not as easy to fix as I thought it would be.
When I receive the new tubes I'll put them on a shelf until a front end service is needed. Not worth the work to replace the tube just for the scratches.
Is anyone aware of a spray touch up paint? I may be able to repaint the small area still on the bike...
