Now I'm at a loss
Moved the clip down one toward the pointy end of the needle. That did
reduce the popping considerately. Still have occasional decel popping, but
it's not very loud.
The problem, at around 50 and up I've got a slight engine miss.
Don't know if it's maybe an air leak or not getting fuel?!?
Also did a full throttle plug chop. It's black as night!!! The 132 main is the
leanest included with the carb. Don't know where to go from here. Except
maybe 50 miles to my dealer
Anyway here's a pic. I modified the chrome cover to fit the K&N that came
with the kit.
Ok, you need to do a clean plug chop at the speeds where you're getting your miss.
And make a close observation of the exact throttle position. Use some tape on the throttle housing to make a little throttle position scale, and fix some kind of pointer or mark on the throttle. Mark the tape to correspond to the pointer at various throttle positions, so you can see at a glance what throttle position you are at when it happens.
Once you know where the problem is occurring(in carburetor terms), then you can use the basic Mikuni tuning guide to determine what parts are governing the fuel mixture at that throttle opening, and take steps to remedy.
That's the only scientific way to approach this, as long as you are sure that you don't have an air leak and that your float level setting is correct.
If you take it to the dealer, this is the process that your dealer will use to do the adjustments. They don't use magic. They have to do the same stuff that the rest of us have to do, except you get to pay them to do it.
BTW, if it is happening at 50mph in top gear, that's a pretty small throttle opening, and could be still in the range governed by the pilot circuit. You might try an enriching adjustment on the pilot screw, and see if it gets better. You might have to then increase the idle speed screw to get it to idle right.
If that fixes it, you may then be able to work that needle back where it was, and possibly get it less rich at the top end that way.
Don't get discouraged. This is what carb tuning is all about.
Once you learn this stuff, you'll be a "carb-meister", and it will never baffle you again.
You'll be able to give advice to other people then.
