Pulse valve removed,
catalytic removed,
exhaust muffler inards removed and replaced with perferated stainless steel pipe,
air filter box removed,
pipe from air filter to carb intake tube removed and adjustment needle closed,
air breather pipe from pulse valve to air filter box now useless removed.
Needle on carb slide moved up one notch. Bike runs bloody great, starts first time and pulls much better.
The air filter box is an ugly thing and annoyed me from the day I bought the bike in India. It is a horrible thing when you look at it on the floor. The removable sludge tray on the bottom of the air box is real India quality.
I fitted a little 45mm intake filter,-- 3 dollar.
Its opened up the breathing to the point that I might raise the needle another notch as she needed a lot of choke this morning and its 30degrees here everyday.
She obviously liked all this attention.
