Author Topic: Center Stand Question  (Read 1586 times)
on: June 02, 2014, 09:19:58 pm
Will the EFI Electra 19" wheel center stand work on my '58 Trailblazer?  I need to replace the mine and 16.50 GBP for a used steel stand in excellent condition is a HELL OF LOT than 72 GBP for the original cast one.  I don't care about it not being original, I just need to know if it will work.
ERC - Can you take some measurements of the width where the mounting bolt goes thru the top of the center stand?  I know you have 2 of everything in your garage.  ;)
Thanks!
Scottie J
ERC
Reply #1 on: June 03, 2014, 01:51:21 am
I just closed everything down I'll have to write myself a note"because I'm old" and measure it in the morning. Something tells me I tried this and it didn't work. Let you know tomorrow. Unless someone with a brain knows and answers before me. Just got through fixing my wifes computer. Bill Gates and I will definitely have a tussel if I ever meet him.  :P  ERC
Reply #2 on: June 03, 2014, 02:57:04 am
Adrian in the AVL section said it does bolt on and basically you just have to modify the foot lever on the stand to clear the exhaust pipe.  I also looked at things closer on H's and there's a foot note that says "will fit older Bullets" and the vintage twins and vintage Bullets use the same center stand, so I should be all good.
Scottie J
ERC
Reply #3 on: June 03, 2014, 03:39:10 am
That's the reason I didn't use it because it hit the pipe. If you use the 2 into one pipe I think you'll be OK.  ERC
Reply #4 on: June 03, 2014, 04:36:09 am
I was just going to hack the foot lever completely off.  I don't have one now so it's like I'd be missing it.  ;)
ERC
Reply #5 on: June 03, 2014, 01:48:21 pm
The foot lever makes it a lot easier to pull up.  ERC
Reply #6 on: June 03, 2014, 01:55:30 pm
Well, in that case I have 1" pipe and a welder.  :)
