Roland, What Bosch plug did you pull out vs the NGK plug ?... Heat range wise ? Is the plug fouling at idle or around town slow speed stuff ? Or you take it out for a good run and it's fouled ? How is the motor currently modified ? I don't know amount the twin spark IDM bike's MAP, But the ones here dump a lot of fuel in at start up and idle... so depending on how your motor has been modified, -5 MAY still be too rich at zero throttle position and say... 500-1250 rpm's. You shooting for a richer start and idle, but not too rich. Shoot for a target afr of around 12 to 1 at cold idle and tweak it from there. You may have to go a little richer or leaner from there. and don't forget... your idle air screw is going to play a roll. Your looking for the best combination, for the way your bike has been modified, for the plugs heat range, AFR's, idle across the range from start up to WOT rippin' down the highway.
