Hello all, I'm hoping I can get some help with a diagnosis. I'm hoping it is just a simple pushrod adjustment but...
My bike is a 2004 kick only 535. Runs great. No leaks. Rebuilt a couple of years ago with Ace's help.
As I pulled into my driveway this afternoon I heard a loud metallic rattle/clack that was in sync with the rpm. There was also a small oil weep from around the spark plug. I let it idle and listened to the noise which seemed to be loudest from the right side of the engine, up the top end. The engine was warm from the ride home (which it behaved perfectly). The bike idled about a minute then died. I restarted it a moment later and it fired to life, but it died a few seconds later. Rattle kept pace with the RPM as I gently rolled the throttle. There was no smoke from the exhaust.
I noticed the oil weep around the sparkplug. I pulled it and it is filthy sooty,but not wet. I haven't changed my jetting or timing or anything like that.
My pushrods had a very slight up/down wiggle but they were not excessively loose. The inlet was moveable with finger pressure and the exhaust spun quite easily.
I had other chores to attend to and didnt' have time or daylight to check it out further. I'm hoping that a pushrod adjustment will fix the problem but I somehow don't think they are the culprits.
What else can I check? Rockers? Valves? Broken oil ring? The piston is an Accralite inside an alloy Hitchcock's barrel, with about 13,000 klm worth of use.
Thanks
I
