if you don't hear the fuel pump, you should have a look in the fuse box:
here you'll find two black square relay, on of those commands the fuel pump, it often pull out with vibration, i put a strap on mine so that it doesn't happen again. (it's very dangerous since it can happen while running the bike and suddenly no fuel!!!)
if not, look for an unconnected wire, or a dead fuse but don't panic there's few chances the pump is dead...
Ben
