Two main possibilities would be not gapping the rotor.stator gap when you installed the alternator, or there could be a shorted wire where the alternator wires go thru the top of the inner primary chaincase.
If the first possibility is true, then your alternator is toast.
If it is just a shorted wire, you may be able to repair it at almost no cost.
